We've been getting stuck on Sly Sports 4 now and cannot get any other channels. Can't even press menu button without it rebooting over and over. Gonna update to this software and see if it helps.
We were told it was not a clone from the seller either, so I'm thinking we've been ripped.
Got it from here:
_http://maxsat.co.uk/openbox-receiver-p-89.html
D.
Or you could take a look here, before you go to too much trouble
Got it from here:
D.
Unplug the feed at the back of the box, reboot, now go into menu and delete the channel.
This is well documented, the box is ok as I guess is the supplier !!
How about the crackling audio on AC3 output at high levels?
I'll download and check it out. Feedback will follow in the next day or two.
I'm beginning to think the crackling audio issue may have been rectified by this firmware. I haven't noticed the problem since flashing and I've watched a couple of movies with pretty high audio output.
Anyone who has previously experienced the crackling audio should definitely give this firmware version a go.
avatar-bombing of home tree= no crackling
fast and furious 4, explosion at beggining= no crackling
Factory reset...........done
new firmware added.......done
L53 sat list added........done
28.2 scanned.........done 830 odd tv chans found
favourites added...done
cfg added and activated......done
Now here's the issue. No sly sports 3 HD. 2 x Sly 3 HD show under all chans but both show no signal. Sly HD1,2,4 etc fine
Also no Setanta or Espn ( no signal). Some Hd movies the same.
Rescanned and still no signal on certain chanells.
Just go to king of sat and get the frequencies of the channels you are missing and manually tune them yourself. Then go through them and delete the rebooting ones
