?Classed as a clone...?
  • torreal
    • Apr 2011
    • 13
    Hello,
    First post here and are a little confused with the receiver I have.
    It is a SKYBOX S9 HD PVR with the folowing in the 'Information' menu:-
    MAC 00-18-BD-5A-74-02
    MACHINE 06-07-01-01-00-00-00-00
    NC 60-74-30-72-7c-7c-c7-b4-35
    Version HDS2-10-10-29 1023CMT
    Bought here in Spain, where I live.
    Nice to set up and no probs with the motor settings and the tuner seems to be very sensitive....great quality picture and impressed with the Blind Scan.
    Is this box classed by yourselves here as a OPENBOX clone and am I likely to have the problems I have seen reading the various threads, examples:
    .........'how did you brick it? is it a clone or original?'
    .........'After i put the march-15 firmware it has stopped saying my box is a clone and bricking it.
    Was going to upgrade the firmware as per this thread
    _http://www.digital-kaos.co.uk/forums/f184/openbox-s9-hd-pvr-linux-satellite-box-158127/index26.html
    All the suppliers will say is that the receiver is as sold ie: a SKYBOX so the question of discussion of Openbox is not relevant.
    Anyway, your comments will help on this matter.
    Thanks for reading this.
  • SG8
    • 129
    If you don't NEED to upgrade the firmware I would leave it alone. If it ain't broke, don't break it in the hope of making it a bit better and maybe bricking it!!
    • dell_xps
      • 2558
      Same box, just a different name, google it.
      Skybox/Openbox.
      • gsmtech
        • 264
        Skybox/openbox/solomend 800HD/SatHawk 800HD all of them are reported to be clones of the Ferguson Ariva.
        • torreal
          • Apr 2011
          • 13
          Ok thanks all for the speedy replies.
          • hooley
            • 470
            The skybox is just another name for the openbox. You should be safe enough to upgrade. As has been mentioned already if you have no problems there is probably no need to upgrade. The only reason i upgrade my box is because i look after another site and i need to be uptodate.
            The name Skybox isnt used much in these parts id say to avoid confusion with Sly uk
            • torreal
              • Apr 2011
              • 13
              Originally posted by hooley
              The skybox is just another name for the openbox. You should be safe enough to upgrade......
              Yes, here in Spain Sly is basically a taboo topic and nearly all the 'pinch the beam and retransmit' characters have dropped all Sly content.
              Anyway, thanks for the upgrade nod, did install the latest firmware you mention and is working well, no reboots and have managed to config the BISS system syntax......nice to see this working with this receiver.
              You mention in this thread:-
              ''Theres a new function allowing you to load softcams to open up a few packages that can still be opened this way.''
              ?What exactly is this....what path in the Menu takes you to this option?
              I open the BISS channels using the 'CCCam Client setup' but in the option 'Manage Config Files/4.Sotcam.key' the actual softcam.key file I have loaded does not appear!
              I have the four 'Manage Config Files', CCCam.cfg/CCCam.prio/Constant.cw and Softcam.key and the BISS channels open ok editing and using the Constant.cw option offline.
              ?What am I missing here?
              Thanks for your time with this
              • hooley
                • 470
                To load a softcam:
                Dump by usb >Misc Files >Slect & Dump
                option number 6 Softcam.key (CCcam Plug)
                Green then yellow
                done
                • torreal
                  • Apr 2011
                  • 13
                  To load a softcam:
                  option number 6 Softcam.key (CCcam Plug) Green then yellow
                  done
                  Excellent...a great receiver for the money.
                  Thanks again hooley
