latest openbox firmware
  • DW190
    #121
    Originally posted by CrAcKeDuP
    Should this firmware work with the S9, as when I tried it only the network and USB functions were available. Every other setting in the menu was blanked out....any help much appreciated.
    Probably because all the channel list has gone and all other settings.
    You sure the sta scan has gone as well? If it has you will need to reflash.
    • ASTROBOX
      • 163
      #122
      Openbox s10/orton clone box
      Hi to all quite new to this box recently download the abs file for Europe to try on the media player issue that i'm facing with the default software i recieved from the supplier in China,for info mine is a clone set i guess.
      ok after download this file i edit the satellite list to suit my region that is SEA using C band motorized dish FTA channel,use the usb stick to upgrade the firmware wallah! all the list is there & got no issue playing mpeg & vob video i'm so happy now that i can use both format for my S10 & Dreambox 800hd thanks for this great firmware.
      PS : Still got a lot of reading in this forum for S10 box
      • ASTROBOX
        • 163
        #123
        S10/Orton Clone
        Just to update using Openbox_s10_nds abs file found in #99
        more stable for clone set, i'm using it right now however the media player won't auto play to next video eg music video is like individual file try to rename it using serial no still the same any expert can guide on how to solve this, can it be play without stopping like DM800?
        • ASTROBOX
          • 163
          #124
          Openbox S10
          Sorry all bro mine i confirm check is original, the chipset is 00EA
          So it should be original S10.....
          • qualitvman
            • Nov 2011
            S10 firmware
            Hi guys this is my first post, i've successfully put in new cc@am lines on S10 but its freezing all time, what the best firmware please, this is my first post!
            • silverlake
              • Nov 2011
              #126
              Skybox S10
              My STB is branded "SKYBOX", and the splash screen at bootup displays "SKYBOX". I was told that SKYBOX and Openbox were the same.
              Can I install this new firmware on my SKYBOX S10?
              thanks!
              • termiantor
                • 400
                #127
                yes you can mate
                HAD THE PARTY LOL
                • silverlake
                  • Nov 2011
                  #128
                  Thanks Termiantor... and can I come to that party?!
                  • silverlake
                    • Nov 2011
                    #129
                    Firmware Upgraded. Splash screen now says Openbox. I had to do setup from scratch - including entering satellite location for the satellite we use in New Zealand (Optus D1). All OK now.
                    • stephensmith23
                      • Nov 2011
                      abs / dbs ?
                      I have an openbox s11 thaat seems to use .dbs format but all firmware downloads seem to be .abs do i need to convert or just change the extension ?
                      • a3nca
                        • 7
                        #131
                        CCcam does not cause the box to freeze, it's either the server that you are using or your internet connection or both!
                        • a3nca
                          • 7
                          #132
                          Originally posted by termiantor
                          yes you can mate
                          I'd like to come to that one and I'll be throwing one when Blair dies too! You are all welcome
                          • codezs
                            • Nov 2011
                            #133
                            wow this forum is great!
                            just wanted to say hi,
                            is there a s12 box?
                            • slugworth
                              • Nov 2011
                              • 1064
                              #134
                              12v
                              is there a s12 box?
                              12v external power supply,that looks interesting.
                              • andyasen
                                • Dec 2011
                                can any one tell me how to upgrade firmware?
