New Official OpenBox S9 Firmware [11-05-2011]
  • trauma
    • 74
    So here we have a firmware that Clone users can use to test their boxes !!!!
    Note the 10 reboots only warning !!!!!
    How to identify clone Ali3602 HD Receiver
    all consumers :
    if you have an Ali3602 HD Receiver like S9,S10...there has a method to identify if it is original (quality goods) or clone.
    Before identify , please backup your old software on the box by usb. Download CONM_CHDS2_CMT_110509090D.rar upgrade it by usb.
    enter menu---tool---information---press "8888" key, now you will see CHIP ID , If the box CHIP ID is in the chip_id_list, congratulatation, your HD Receiver is original version! You can upgrade any new firmware to experience more new functions. Otherwise, You Box is clone version , please recover the software with the old version! This software will kill the clone box when power on over 10 times. If less than 10 times, no kill for clone verion.
    the chip_id_list is the following, it will update everyday:
    00D0
    00EA
    085B
    0D0C
    98A1
    98F2
    9CF4
    9D1A
    When you buy a new box , try to view the chip_id_list on this http page. If you can not find the valid "CHIP ID" on the chip_id_list, it means your box is a clone box.
  • khurshid
    • May 2011
    The problem of " marrying" the box with card still remains with NDS. Any solutions
    • sombel
      • Oct 2010
      • 47
      all consumers :
      00D0
      00EA
      085B
      0D0C
      98A1
      98F2
      9CF4
      9D1A
      This firmware didn't work on my receiver even though i have renamed the software in .abs file
      • psgpol
        • May 2011
        • 17
        there is something wrong with this firmware. my CCID is 085B but i've got CLONE info after 10 restarts
        look at picture:
        • rrob311
          • Jul 2010
          • 184
          I have the 9D1A chip ID. What is the best firmware available and what new functions does it have?
          • psgpol
            • May 2011
            • 17
            write new firmware from upper link and check. this is newest firmware for S9 with lan function.
            • hooley
              • 470
              Rob, there is different firmware for users from USA.
              • trauma
                • 74
                For those of you who have a motorized setup, and wish to open the BISS channels, then you will need to install the previous Official Firmware HDS2_CMTS_20110506, as that will then allow you to open the BISS channels [with the appropriate keys]
                As the latest firmware has a small bug, and will not open the BISS channels, even with the correct keys.
                • alphaque
                  • May 2011
                  • 12
                  look at picture:
                  hi
                  is it confirmed no where you can recover your box ? 085B should be a valid CCID, why it got killed. this really puzzles me
                  • psgpol
                    • May 2011
                    • 17
                    yes it's tru i;m confused too. my CCID is 085B but my s9 got killed after 10 restarts. now i can't revive it becasue bootloader are damage. erom tool can temporaty fix my box it can boot and power on normally but after 10x restarts again CLONE info.
                    this firmware i designed to kill as much S9 as they can. look at my picture, under clone version info you can see CCID 085B which is valid but s9 got CLONE.
                    • trauma
                      • 74
                      If the CCID chip is valid, but your receiver is displaying the clone message, I would guess that the problem is either a conflict, or possably even a damaged chip, either way you should simply return the receiver back to your supplier.
                      And he should then either replace it, or repair it free of charge for you, and as your also still covered by the statatory 12 month guarantee, there should be no problem.
                      • IAmGreiG
                        • Jun 2011
                        • 11
                        just got one of these boxes and looking to update to the latest firmware. Im hoping I haven't ended up with a clone.
                        CCID is 0202
                        • kreeck
                          • Jun 2011
                          im new with s9, and make a wrong update, now with recovery is freezed in "edit chanel page" i hope this rom help me.
                          • karimsalim
                            • Nov 2010
                            • 4
                            085B is clone
                            • KMNO4
                              • Sep 2011
                              when I press 8888 regarding the instructions here is nothing appair.. Does it mean my pvr is clone ?
