Can you let me know how to add channels please? thanks
How to add new channels ??
Scan the satellite for your missing channels.'If you are neutral in situations of injustice, you have chosen the side of the oppressor. If an elephant has its foot on the tail of a mouse and you say that you are neutral, the mouse will not appreciate your neutrality.'
-Bishop Desmond Tutu -
Im not sure what you are after, do you want to know how to add a channel list ?'If you are neutral in situations of injustice, you have chosen the side of the oppressor. If an elephant has its foot on the tail of a mouse and you say that you are neutral, the mouse will not appreciate your neutrality.'
-Bishop Desmond TutuComment
Thanks for taking the time to ask.
I currently have a set channel list, loaded from usb which is great as I can scroll through without have reboot on any channels.
I want a few channels that are not in this list, to get to view them I have to right, select all satelite and page up and down to find them. Too many clicks to go through and you get moving dish sign.
Have tried to add to favourite, this works but still too many clicks and moving dish menu.
Willing to put up with it, but anyway to add the channel to the already set list I have, without having to change satelites or lists?
Thanks in advance.Comment
Sorry I don't think there is any other way to do it, other than creating a complete new list of your own which would be much more time consuming. Which list are you using ?'If you are neutral in situations of injustice, you have chosen the side of the oppressor. If an elephant has its foot on the tail of a mouse and you say that you are neutral, the mouse will not appreciate your neutrality.'
Using TP Prog.rar list, cant be that hard to add just one to the list even when using a editor can it? Just need to know what the frequency is??
If I can find the original person who made the list, maybe ask them as a favour??????????
Seems to be a fair few people asking the same question.
ThanksComment
Get the freq from king of sat , then go into transponder list and either manually enter the new freq or scan the tp the channel is on. Then go to channel menu lust and move it wherever you want it. Finally to save your new list go to dump by USB , pick misc files and then select tp prog and dump it to USB in back of box. Press info when finished to see if worked. You should now have amended list saved on USB for whenever you upgrade firmware.Comment
Did this, it adds the channel as before to all satelite channel view. Doesnt populate it under the astra satelite.Get the freq from king of sat , then go into transponder list and either manually enter the new freq or scan the tp the channel is on. Then go to channel menu lust and move it wherever you want it. Finally to save your new list go to dump by USB , pick misc files and then select tp prog and dump it to USB in back of box. Press info when finished to see if worked. You should now have amended list saved on USB for whenever you upgrade firmware.Comment
You have a few different satellites channel list. When you scan the channels you are missing they would go into the big list of each different satellite. Can you not just go to that list and then move the channel to one of your favourites. You can do this in the menu of the box. I was asking what list are you using to see if there is favourites with it. That's all I can think you are asking to do, is it?Comment
