OPTON / OPICUM X403p Better than S10
  • GADOTOR
    • Oct 2011
    • 11
    #91
    dercu5 l wish you shd change your picture,is very offensive.thank you
    • darcu5
      • Jun 2011
      • 944
      #92
      there you go i've took it off, sorry if you was offended by it; but in all fairness looking at my picture isn't going to fix anything for you, more likely to give you nightmares
      If it isn't broke, don't try fixin it..!!!
      • mohammed m umar
        • Dec 2010
        • 5
        #93
        I got both orton x403p and openbox s-10 after testing i found out that orton is better than s-10
        • baben
          • Nov 2011
          Greetings for this software openbox s9 olurmu?
          • Tommas
            • Nov 2011
            #95
            Hi I need help please. I have just received an Orton HD X403p satellite receiver old type remote from my sun in the UK and need it to be set to the satellites in South Africa. The dish is set up for the Astra 4a at 4.8* E, Astra 1C1C E19, 2 and used to work fine on my old Satellite Perfect SP100. I am not to clue up on downloading files from the Internet and where. All help will be appreciated.
            • searius
              • 16
              #96
              so nobody have any problem with dolby digital audio on HD CHANNELS
              • shearer9uk
                • 103
                #97
                searius
                got digital output to dts amp getting 5.1 sound of most HD channels
                I use the HDMI to connect to TV but have never tried to see if you get sound thru tv.
                • falasha
                  • May 2011
                  • 5
                  #98
                  Hi Tommas,
                  Do you want to know how to configure the channels or what did you mean by downloading files from the internet?
                  • GADOTOR
                    • Oct 2011
                    • 11
                    #99
                    Thank you darcu5
                    • kadnor
                      • 78
                      #100
                      Originally posted by jkwel999
                      adeobolo I tried all Firmware none of them connected server after long search i found this Firmware working fine
                      has there been any new firmware released since june?
                      thanks for advising.
                      • jokerone
                        • Dec 2011
                        Newbee
                        hallo all, I'm newbee , very interesting site.
                        Good work
                        • Fano
                          • 331
                          #102
                          I have the same issue on my Orton 403p,it wont downmix the dolby digital channels.
                          I tried numerous types of firmware but they all had the same issue.
                          I bought it off Alibaba too like yourself.
                          I think its a hardware fault ,a few other people on different forums have the same problem,there is no solution.
                          • pitodenz
                            • Dec 2011
                            hello pls i need orton new firmware
                            • Hooper
                              • Feb 2010
                              • 10
                              #104
                              Best to google Opticum firmware.
                              • biss1
                                • Dec 2011
                                • 4
                                #105
                                I have just loaded this firmware (ALI3602_06020200_globo_OPTICUM_HD_X4_220_ps_amsta r_1.4.34) to my Orton x403p. The firmware is okay but it does not have the cccam entry function in the internet segment. How can I add this function. Thanks.
