lost my v channels
  • steven3367
    • Oct 2010
    • 21
    lost my v channels
    lost my v channels but these still work on my skybox is my tuner knackered
  • calhib
    • Sep 2009
    • 236
    have u tried deleting the satellite and rescanning all of the channels instead of just the specific 1s
    • steven3367
      • Oct 2010
      • 21
      its my higher freq ones on v that are knackered been in touch with a sat engineer and he says the tuner is on its way out i can still get them on my sky box and my sat tv just not on the open box
      • kevhky
        • Dec 2010
        • 153
        It's the tuner matey they ain't the best to be honest, I had same prob but all was fine on dreambox
        Kev
        Receivers
        OPENBOX X3
        Skybox M3
        DM528 - PliJade
        DM500s - PliJade
        Technomate TM500 - UR
        If you like my posts press the "Thanks" button to show your appreciation
        • trauma
          • 74
          Kev
          You say the tuner is at the root of the problem, but I find the tuner realy sensative, for example BADR [26e] & NILESAT [7w], the tuner will give me access to a number of channels, that certain other receivers can not even achieve a lock on.
          Exactly what satellite and channels are you refering too, then I can check them out, and see if I get the same results.
          • steven3367
            • Oct 2010
            • 21
            i couldnt get any movie hd channels apart from mgm and showcase i looked this up on king of sats and they are all on the same freq all v
            • trauma
              • 74
              I can think of two possable causes that may result in the loss of a polarity.
              1 .. Your dish requires realignment, which I would guess is your problem.
              2 .. Your Lnb requires replacing, as a result of an Lnb failing, one of the most obvious signs is the loss of a single polarity, but if that was the cause, then you would lose all vertical channels.
              • koshba
                • 34
                Try an In-Line Signal Amplifier Sky Satellite Booster about ?4 on the bay.
                • trauma
                  • 74
                  A booster for Sky, well I guess if your cable run is 50metres or more it may help, or even if you live abroad, but if your in the UK and have a standard cable run, and your dish is correctly aligned, then there should be no need for assistance regarding the signal.
                  Remember when using a signal booster it also increases the noise along with the signal, regardles of wheather your using a passive, or non passive booster.
