itv1 hd
  • dionne
    • May 2011
    • 44
    itv1 hd
    any body have any probs with itv1 hd being out of sync
    on openbox s9 hd pvr
  • eattheliving
    • 331
    yep, it was only a tiny bit but i did notice it. usually if you change chanel and back it corrects it. i couldn't be bothered tonite so don't know if it would have worked or not?
    • moulee2009
      • Apr 2011
      • 56
      Not just the openbox to , i have a new dm800hd and the sync was off on itvhd
      • hooley
        • 470
        Ya, same with my dm800 also. Just a fraction off
        • koshba
          • 34
          theres about 6 diff itv1 hds,i had the same problem last night,i deleted the 1 i was having problems with and used 1 that was in all channels dm800hd and all is well.
          • moulee2009
            • Apr 2011
            • 56
            Originally posted by koshba
            theres about 6 diff itv hds,i had the same problem last night,i deleted the 1 i was having problems with and used 1 that was in all channels dm800hd and all is well.
            Thanks , i will look into this
            • bernado
              • Feb 2011
              • 89
              I've got 2 ITV1 HD channels, as that's all you get on FTA - ITV London and ITV Granada. ITV Granada is the one you want to keep, as this has mpeg audio, compared to ITV London (and probably the others) which uses Dolby AC3. I think it's ITV's implementation of AC3 audio that causes the problem, although I have no idea why; my other HD channels with AC3 play fine. Interestingly, if I play ITV1 London through my Dolby amp via S9's digital audio out, it's in sync. So it's something to do with how the downmixing is handled, by the box itself or the TV.
              Handily, Granada broadcasts the video at a higher resolution compared to London, so it should be the best option anyway (unless you are using a surround set up)
