Its not copied correctly. Was it given as a .cfg file? Or a line and you have saved it to your USB. If so use notepad copy it to there then resave as a .cfg file and not a .txt file
The easiest way to add lines is by remote. The first bit is the server, the number is the port, next number or text is the user then last bit number or text is the password
Press Ok then it comes on click active so it has a tick, then exit it will save.
Press standby then again to reboot. Should now be working. To check go back to Cline and make sure it says Online next to it
given as a cline with ftp in it,do i just copy and paste or do i have to do owt else,dont no if i read somewhere that you have to insert letter f in the line could be wrong
