uk fav including asian channels for openbox 10
  • youngie1
    • Sep 2009
    • 184
    hello all does anyone have uk fav including asian channels for openbox 10. does the same channel list openbox 9 work with the 10 or not cheers all lee
  • homer41
    • 207
    yes the s9 lists work on the s10 tried and tested by myself
    • mast
      • Nov 2010
      • 1027
      Try this one I put up in the channels stickie. Post 117
      Its got an asian fav as well.
      • youngie1
        • Sep 2009
        • 184
        ok all i have the openbox 10. all the channels list i am puting on is rebooting the box. what is the best software for this box and channel list please help all cheers lee
        Originally posted by mast
        • mast
          • Nov 2010
          • 1027
          Are you getting the reboot using my channel list. Either way whatever channel is causing the reboot could be one could be more.
          What you got to do is switch box off and take off the sky feed and reboot box then delete offending channel.
          My list was created on the s9 and as far as I know there was one offending channel in the favourites sky news I think which I deleted and it has been fine but that channel is still on the main channel list and needs deleting from there.
          • total newby
            • Feb 2011
            • 183
            hi will this work on a openbox s11 with latest firmware its a original box
            • mast
              • Nov 2010
              • 1027
              Nah m8 its old now look for a newer updated one or in a day or two Il post one that Im making up now if it will be of help.
              Im making it on a s10 and not sure if it will work on s11.
              Regards
              • mast
                • Nov 2010
                • 1027
                As I said that I was doing a list and Ive just uploaded it if you are still interested.
                Ive done it on s10, by all accounts it should work on s11 but try and get someone to confirm if you do decide to use it.
                Regards
