L53 Openbox S9 Multi-Satellite Channel List v4.40 [14 May 2011]
  • trauma
    • 74
    This channel list is best used with either the latest official Firmware, or with the latest L53_MOD_Dump file.
    This is a multi-satellite channel list covering satellites from 30west to 45east.
    It can also be used as a single satellite channel list, just click on the Zoom or SatList button and select the satellite you wish access from the satellite list.
    Default Settings:
    Channel list format: .dbs
    Default Motor Setting: DisEqC 1.2.
    Default LNB Setting: Universal [9750 - 10600]
    Radio Channels: 0
    Favorite Channels: 0
    If used in an external channel editor, change extension from .dbs to .abs
    once you have edited the channel list, change the extension back to .dbs
    What's New:
    Updated channels on various satellites including: 13e, 19.2e, 23.5e & 28.2e.
    I believe all the channels that caused rebooting problems, have now all been removed.
    To optimize this list & receiver to it's full potential, you will require a full multi-sat coverage cline.
    I have also decided to included the replace.list and constant.list in all future releases, only for those that may require them.
    Of course if you already have them installed, then simply ignore them.
    Please Note:
    To avoid any possable conflicts, it is always wise to delete all channels from your receiver, before installing a new list. if you do not then you could possably encounter problems.
    To remove all channels, click Menu -> Edit Channel -> Delete All
    To install this channel list, simply transfer the unzipped channel list to a USB Stick, and then insert the USB Stick into the USB port, which is located on the rear of the receiver, then follow the instructions below.
    Click Menu -> Tools -> Upgrade By USB, then in 'Upgrade Mode' select 'Misc Files'
    then click on 'Select & Upgrade' and select OPTION 1 [TP_PROG] now click the OK button,
    when you see a check mark or tick next to the TP_PROG, click the yellow button to install.
    Once the file have been installed, reboot the receiver, once rebooted you can then click the Zoom or SatList button, and directly select any satellite from within the satellite data base list.
    All the best
    Laurals
    New settings for TRING.
    As the settings were changed since the release of the channel list,
    you will need to rescan the following settings in order to gain access.
    Eutelsat W2M [16E]
    11.283
    V
    27500
    5/6
    ITV 3D [Testing] New
    Astra 2B [28.2E]
    11.973
    V
    DVB-S QPSK 27500
    2/3
    BBC HD & ITV HD Updated
    Astra 2D [28.2E]
    10.847
    V
    DVB-S2 QPSK 23000
    8/9
    As of the [24 May 2011] I will be disconnecting the OpenBox S9, and will be running the Blade BM 7000 HD as my primary receiver, so I shall not be releasing any further channel lists, or making any more tutorials for the S9.
    If anyone wishes to release their own multi-sat channel lists for the S9, then please feel free to do so.
  • doctorm
    • Jul 2011
    hi, i have used these list and i can not use the menu antenna setup!! you can not choose option to change motor settings. i have in my box last firmware 30/06. thank you
    • trauma
      • 74
      Then your obviously doing something wrong, as I'm using the same list, and it's okay for me.
      • doctorm
        • Jul 2011
        how i can be wrong?? it is one file to download to your usb disk and install in the box. do you use this channel list with last firmware 30/06? or you are using other date firmare
        tell me how you install it
        • zenicablues
          • Aug 2011
          is there any option to use channel lists from other sat receivers?
          • jockyboy12
            • Aug 2011
            • 18
            looks like i'm doing something wrong aswell cause my s9 with official fw don't recognise the file
            edit....got it now thanks
            edit again...the bar went accross as if to update but nowt was put on....looked into info when finished it said there was no file.....so it don't work now on the latest fw
            • kayzerd09
              • Dec 2011
              Thx,
              Is there any update for this ?
              • geopopo
                • Feb 2012
                • 7
                ye, another multisat channel list would be great. I have sats facing hotbird 13 and astra 28.2
                • valery39
                  • Nov 2012
                  Channel list
                  Where can I get the latest channel list from? I just purchased an s9
