openbox cs10 cccfg not correct on box
This topic is closed.
  • spudorange
    • 242
    For some reason I can not get my FULL cline into this s10.
    I have flashed the following all with same results.
    OPENBOX_S9_HDS2_EuropeVer.abs
    SKYBOX_S10_CTM.abs (openbox_S10_26_06_11)
    My cline server name has 25 characters in it but when usb'd to box it drops the last character *****ftp.net becomes *****ftp.ne
    removing an earlier letter say f from ftp returns *****tp.net
    So in short 24 characters is the maximum I can have
    It came with a flash already working (with hd glitches) but I did not know that so checked it was original then flashed.
    been at it for hours & hours now and only fully understood what was causing it an hour ago.
  • darvash
    • Aug 2009
    • 51
    Using IP address instead for server name can you solve the problem temporarily.
    *****Don?t argue with idiots. They drag you down to their level and beat you with experience*****
    • dell_xps
      • 2558
      Stick it on a usb and flash it that way m8.
      • spudorange
        • 242
        Sorry m8, lost me
        can you explain better for me thanks
        • spudorange
          • 242
          That's the way it was done (usb)
          can not edit cline on box, I can add new but as the colon in c: is not available theres no point,
          I can get full stop, comma, apostrophe etc but NOT : so can go no further.
          • dell_xps
            • 2558
            PM your c line m8, i'll have a look at it.
