change channel list from dbs to abs
  • damo2010
    • Oct 2010
    • 125
    hello all ive got a channel list now but carnt put it on my box becouse it an dbs file not abs
    so i changed the name to abs then it says file mismatch
  • SG8
    • 129
    Are you changing the name or just the file extension ?
    • damo2010
      • Oct 2010
      • 125
      the name
      ive right clicked on file
      then deleted the last bit at the end DBS
      then replaced it with ABS ???????
      • SG8
        • 129
        You don't need to change it at all, if you are just loading it straight onto your box.
        The .dbs extension will work on the box, but if you need to edit it (using the channel editor program) you change it to .abs , edit it, save it and then change it back to .dbs to upload to the box.
