On some channels my signal level drops down to around 45 and channels dnt clear at all , every nw and then u see a slight pixilation . It seems all on the same frequency too
Some channels not working
iv also got this problem, my signal level stays around a constant 76%, the freeview channels work fine and the sports channels in hd work fine, but the hd movie channels are just unwatchable, had my vu+ duo on the same sat feed and that never jumped or pixalated at all, what could be the problem. openbox s10 with latest firmware, all help appreciated!Comment
thanks for the heads up m8 ill check my s9 when i get home and report my findings... by the way my s9 is plugged into a td110 dish so signal shouldnt be a issue on 95% of channels. regards mdtiv also got this problem, my signal level stays around a constant 76%, the freeview channels work fine and the sports channels in hd work fine, but the hd movie channels are just unwatchable, had my vu+ duo on the same sat feed and that never jumped or pixalated at all, what could be the problem. openbox s10 with latest firmware, all help appreciated!DM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30WComment
really dont understand it mate, got sky sports hd on here and its never missed a beat, all the sports channels are mint, cracking picture on them by the way, but the movies just dont seem to want to know, picture breakup is horrendous, oops iv just switched it over to sky sports 3 hd there and its barely showing a picture at all, could the box be ~~~~ed do ya think! i know its not the c line im using because its coming from my own server which is rock solid! BAFFLED!Comment
something in these later f/w`s is degrading the signal quality , on old f/w pulled 95% ,new f/w is 70% and lower on exact same dish/cable.
pretty sure all these later firmwares are clone issues (skybox) , seems to be some conflict and degrading of signal quality when using them on original units
Check the F plug connection as this can mean a drop in
signal levels if not correctly inserted.
I went to a house last night & his signal had gone off, but when i looked around the back of the box, the sat cable was a bit loose, so i put another F connector on & used some
amalg tape to stop the cable moving & signal is now back on at about 76%.Comment
im getting that signal mate aswell on the normal sd channels and some hd channels, nothing wrong with connector as iv had my vu+ duo working on the same sat feed for months, also tried my 500s last night just to test the feed itself, and both worked flawlessly like i knew they would anyway!Check the F plug connection as this can mean a drop in
just some of the hd channels mainly movies and sport either show no signal, or about 5-7% signal, iv contacted the seller i bought it from and there giving me a refund once i return box!Comment
can some one help me having big problems with the s9 i,ve posted a few threads on here but dosnt seem to be much help on these boxs,my box is now well playing up just freezing all the time ,the green light is flashing like mad on the front of the box and when u press info twice and get the signal up its going mad up and down and its causing bad freezing ,ive tryed loads of different firmwares by usb and serial port but every one the same,is it ready for the bin or can it be sorted.Comment
