User manual Openbox/Skybox S9/S10
channel list
do you have a channel list for openboxAs almost all the skyboxes and openboxes are shipped without any user manual. If anybody needs that
You can download it her or from attatched pdf doc.
openbox_skybox_User_Manual.pdf
How to edit CCcam+ Newcamd accounts & MGcamd Plug setting Openbox S9
This part is taken from another forum so thanks to author for this tutorial
CS share protocol settings.
Edit CCcam+Newcamd accounts
1. Prepare an available Cccam code like this
C: test.dm700.com 63001 user100 password100 yes
N: test.dm800.com 12000 user1008 password102 01 02 03 04 05 06 07 08 09 10 11 12 13 14
2. Use Wordpad to open Cccam.cfg file , and copy the available code into the wordpad and save it.
3. Then copy the Cccam.CFG file with available code into your U disk root list.
4. Connect the USB drive to HD Box usb port
5. Press "menu" into Cccam setting ,select Cccam Plug Setting and OK.How to make Openbox /Skybox work as a server
6.Select read CCcam.cfg From USB and press OK.
7. After reading account, please select Account Management and press OK.
Activate the sharing accounts and reboot the receiver
9. For MGcamd Plug setting.
10.Edit and Copy the replace.lst and Ignore list to U disk root list, then press " update replace.list by USB device or Update ignore.list by USB device" to load the files and save the files to STB.
12. Network Local settings:
Select Network Local Setting and press OK.
13. At DHCP select "ON" and then select "Apply" press OK.
So the sharing setting is now finished.
It couldnt be easier.
1. Press "Menu"Please don't forget to leave your comments about it. You are also free to use the thanks button
2. Scroll down to "Network Local Setting"
3. Press "OK" on remote
4. Arrow right to "Newcamd Server Settings"
5. Press "OK" on remote
6. Enter newcamd server parameter
7. Server setting -ON-
8. TCP Port -eg. "13000" this must be forwarded in your router
9. Des Key 01 02 03 04 05 06 07 08 09 10 11 12 13 14 (Can be change to your own)
10. Add USER in Newcamd server User manager with green button on remote
11. Add username PASSWORD "Allow emm YES"
12. Press yellow to save the configuration .
Now box is setup for server with 1 client and a reboot is always a good idea .
In the Client box with CCcam its the N: line to use for acces the server eg
N: server_ip_or_dns 13000 USER PASSWORD 01 02 03 04 05 06 07 08 09 10 11 12 13 14 256
