Sky Uk Channel List + Fav Asian 03/08/11
Really Sorry
Here Is the Proper Working File I rarely Come On This Forum Accept My Apology.Attached FilesComment
thanks for your reply i have tried this file through usb but no luck same massege missmatch error.
may be i am doing some thing wrong can you tell me step by step how to upload also the file size only 121kb its bit small size dont you thinkComment
i am not doing any thing wrong i have done this before, just to check it i have treid some one else tp_prog.dbs file and it uploaded fine.Comment
Ive justed tested the file i uploaded on my openbox works fine. what firmware you using on ur boxs. Try Skybox firmware instead 15/08/2011.
regardsComment
Thanks a lot, this is great channel list
I figured out ''remarkable'' what is a problem with you opening it as I was having the same problem. You need to change setting of your folders by going into organize folder and untick the file extension and then unzip it. It will work.Comment
Thankyou
Hi Guys.
Ive Spent 3 Hours Sorting My Openbox Channel Listing To Sky Uk Numbering As It Was Annoying And Sorted The Favourites Out, With One English Favourites And One For Asian. Tested The Files With Latest Firmware And Works Fine.
Channel Are Sorted From 101 Upto 900 Using Wildsat.com
Thank Me If You Like And Anyone Wants To Post On Other Forums Permission Granted.
Regards
Dumbo123
Sorry First File Was Corrupted Here Is Working One. Check Last Post Thanks
Need asian sky uk bouquet. thanxComment
could someone please help me out, im on my first openbox s10 here, but i cant load any of these tp_prog files, i had no problem updating the software to the latest one.
but no matter which tp_prog file i use, it doesnt show up under misc. ive tried renaming them .dbs and .abs, it just shows nothing under misc files.
please help haha.Comment
