openbox S10 audionot in sync
  • greystanes
    • Aug 2011
    hi all just got a new openbox S10 and the sound is not in sync with the picture any idea how to fix ....cheers
  • royboyz
    • 205
    Change channel and back
    If no joy update f/w but do clone check first or you may brick it
    • greystanes
      • Aug 2011
      changed channel then back still the same i dont want to upgrade fw as i think its a clone (its a cheap import from china) any other ideas i can try.......cheers
      • kidbrush
        • 15
        its something to do with the osd, when the osd disapears, it knocks the audio out of whack, try changing your osd setting down to 1 second, this works on most channels,the ones it doesn't work on, try pressing exit as soon as you change channel, the idea is, to get rid of the osd before the channel kicks in..hope this helps.
        • Scampa
          • 4
          Change FW after 17/06/11 fixes this problem
          • Smith23481
            had the same problem in settings menu tv i think i changed an audio setting and it worked.
