wifi bridge to s10 box
  • romdut
    • 68
    Im connecting my wifi bridge upto my openbox s10 for the obvious but the box isnt reading the wifi bridge after i have inserted th cline and also i have installed the software for the bridge and that does pick up the wifi also when its connected to the openbox,
    What am i doing wrong cos i have inserted the ip address and gateway etc.. in the network setup
  • plasterer
    • 1631
    Not to sure on the s10 mate
    But all ive connected via wifi has picked up the connection
    Once the sea lion is in place
    If the connection is correct it has no option but to bridge
    I fear the trouble is with the bridge set up other than the s10
    Does the s 10 work on a straight wierd connection with the same ingredients.................Paul
    If your Happy with the Help push the Thanx button
    PAUL
    • DW190
      Mine works on S9 and S10 without any problems.
      Why are you entering an IP?
      I used the software to connect to the router, entered passkey and that should be it.
      • romdut
        • 68
        Unfortunately the software wont pick up the router
        • webhead
          • 46
          hi make sure you connect bridge to pc then run software,find your wifi name in list put in your password ,then check afterwards that your dongle pics up on pc and its connected browse the web if it works great , but when setting up dongle you have to make sure its on the right type of security , wpa wpa2 ,i think most only like wpa this is the first form of wifi i think, if you done all that and it works , then plug into box start box the bridge should be blue light that means connected, then goto settings and turn network to off then on make sure you got dhcp on dynamic not static, reboot then see if it works you can check by going to ccam and see if it says online , also make sure you activate the cline.if you hanevt and you activate it make sure you reboot.
