S9 Tuner Woes or Bad Server
  • dinsey
    • 30
    hi,
    New user for s9, had the box for about 4 months now. Some channels seem to glitch, pictures goes to scrambled then comes back, or it pixels.
    I have contacted the server people who state that its maybe the s9 tuner, as its not a good box. Dont see other people on the suppliers forum openly sharing the same issues as me.
    Have paid for a years sub, 50 notes.
    Whats shoud I do, do I have a faulty box or is it a server issue?
  • termiantor
    • 400
    hows your fta channels
    HAD THE PARTY LOL
    • royboyz
      • 205
      Server issue but for ?50 what do u expect
      • weirpig
        • 191
        i have a problem too mine comes on for a short while then goes off apart from the FTA if i shut down they come back on and so on.....this has happened since i upgraded software ive tried going back but with no joy.....
        • tw87
          • Jun 2009
          • 233
          Are you using one of the wireless dongles by any chance?
          IF YOU THINK MY POST HAS BEEN HELPFUL PLEASE HIT
          • thisnthat
            its been happening to me too.... all my FTA are good.... got a test line off a site and everythhing was good then I bought a 3 month sub and it went all freezy
            • termiantor
              • 400
              its your line then
              HAD THE PARTY LOL
              • weirpig
                • 191
                as it happens yes but it works fine on my cable box
                • thisnthat
                  Originally posted by termiantor
                  its your line then
                  thought so, even changed my router incase it was causing a problem...
                  • the man
                    • 1660
                    90% of then are scamming ****s , its not just you getting this bs
                    • jojoke
                      • Nov 2010
                      openbox S10 Tuner sensivity
                      I would now your experience with the HD DVB-S2 Sharp 7306 Tuner (integrated on the S10 Openbox).
                      With Astra 1H/1K/1L and Hotbird 6/8/9 results follows.
                      Generally Signal Strength is: 87-89%
                      Signal Quality
                      : 73-76%
                      this give a very good picture if signal could be decoded.
                      HD services generally could not or only be decoded for a short time.
                      However I have artifacts and Image hangs but no reboots.
                      On rare transponders signal quality goes up to 85%.
                      In that case stability and image is perfect.
                      Case for: arte HD freq: 11361
                      Note: the quick scan found 2 'arte HD' (1 scrambled, 1 FTA)
                      Other 'majuscule' ARTE HD?s (all scrambled) could not be decoded.
                      I understand that I have not enough signal quality.
                      But I used this 90cm dish with all my previous decoders without problems (Humax 5400, Triple Dragon, Dream 500S)
                      In addition I installed 2 new LNB's 0.1dB noise figure.
                      And used a Satfinder and Decoder for fine dish alignment.
                      I improved marginally because the previous setup was perfect.
                      A defective tuner: HD DVBS2 Sharp 7306 ?
                      What about your signal quality considered has good?
                      Jo
