does any one no how to retune some channels on openbox s9 pvrhd,has some channels have changed freq,had a look on kingofsats page got the freq,but also i think there is a file called ini ,i think this is the channel changes but dont no what to do with it,cheers
retune channels
DW190
Just rescan on single sat and the new freq/channel will appear in the All list.
The old one will still be there but you can delete. -
DW190
For channels that have changed you'll probably have to remove it from favourites and then re-add the new found working channel into your favourites..
Regarding scanning, if you do a blindscan it doesn't pay attention to any of the TP's in the TP list stored on the box, it goes and finds everything on its own and should pick up all channels that have changed, and also add any new found TP's it finds to the transponder list if they're not already there. If you only do a preset scan it will only scan the transponders already stored on the box, it wont scan anything else.
If you do a Network search with preset scan the box will look for the NIT (Network Information Table) on the satellite, this is a sort of map of the satellite which points a box to the active transponders on the satellite. In some come cases this type of scan might find more transponders than a Blind Scan would do, as a blind scan only waits for so long on one TP before moving on, so it can sometimes miss stuff..
Hope this helps..Last edited by nibblitz; 28 August, 2011, 15:12.Comment
