28.2 Channel List 30/08/11
  • tw87
    • Jun 2009
    • 233
    #16
    Originally posted by wingunners
    hold on i;ll upload it
    That's the same program as PVR800 and AliEditor, just under a different name. I don't know all the shortcuts for it, if someone could post a full list of program commands it might make it a bit easier for me.
    let me know how it goes i really like ur list just need the asian and the first few channels to change to bbc1 hd itv1 hd bbc2
    I'll swap out the HD Channel favourite section and substitute it with the international section for you. The which BBC2 Channel do you want and I'll fix that too.
    Originally posted by bb5
    no adult favourite?
    Dirty boy
    Let me know and I can do the same, swap out the HD Channel list for Adult.
    IF YOU THINK MY POST HAS BEEN HELPFUL PLEASE HIT
    • rabies
      • 34
      #17
      i presume its where you live that decides the channel order ie: BBC1 NI - BBC2 NI - UTV
      i'm in the granada region so had to move things about.
      but thanks for your initial list, its a big help.
      • tw87
        • Jun 2009
        • 233
        #18
        Just Northern Ireland channels mate, UTV is our equivalent of ITV for you. You'll see the website at the end of Corrie or Emmerdale etc. BBC are our regional channels too.
        Doesn't take long for people to edit as per their region, hope it was a help for you.
        • MR-T
          • 53
          #19
          Hi m8
          thanks for taking the time out to share the sky list file,is there any chance you could add stv scotland hd in your list as thats the only thing that seems to be missing.
          many thanks in advance
          regards
          MR-T
          • Digibond
            • Sep 2011
            #20
            How to install this channel list on openbox s10
            Great post. I am in the process of setting openbox s10hd,struggling with it. Could you kindly give me step to step guide about how to install this list via USB. I tried installing it direct but doesnt recognise the fille. Thanking you in anticipation.
            • tw87
              • Jun 2009
              • 233
              #21
              Originally posted by MR-T
              Hi m8
              regards
              MR-T
              Here it is mate, don't know why it's named 3855 but it is. I've pasted it in for you and put BBC1 and 2 Scotland as well. Hopefully you can rename it on the box.
              Here's the file.
              • tw87
                • Jun 2009
                • 233
                #22
                Originally posted by Digibond
                Might not be exactly the same as I wrote this for an S9 but the basics are there:
                Hit Menu
                Go down to tools
                Hit right button
                Select Upgrade by USB
                Change Upgrade Mode to Misc Files
                Select Select & Upgrade
                Select OK on TP_PROG.dbs (a tick will appear beside it)
                Hit the yellow button
                Once completed exit out of this and reboot box
                • j1mjam
                  • 23
                  #23
                  ello mate this is the sky channels with asain listings. also first is bbc 1 hd and also itv 1 hd
                  back up your old epg first...
                  • j1mjam
                    • 23
                    #24
                    is any one getting no signal issues on some channels using the skybox fw? - first s10 box struggling to get it going
                    thanks in advance
                    • opr010
                      • Nov 2011
                      hi
                      Sorry I'm new. is this working with openbox hd s10?
                      • tw87
                        • Jun 2009
                        • 233
                        #26
                        Yes mate but I've done loads since this one, use the most up to date which is 20/10/11
