openbox hdmi problem s10
  • krus2
    • Sep 2011
    • 4
    Hi and welcome and sorry for my english
    Just bought s10,and yesterday I connected it with hdmi cable and everything was okay.
    Today it stopped working, I tried v.format, but does not work, now I connected my s10 with cvbs cable and it's work but is not that good like HDMI.
    Please help
  • nibblitz
    • 1300
    Does your TV support all the output modes of HDMI ? If it has defaulted to 60hhz its possible your TV may not support this, so you may need to change it to 50hz.. Normally in Europe people would choose 50hz, everywhere else 60hz..
    • krus2
      • Sep 2011
      • 4
      Thanks, yes i am in uk, and what is strange it worked yesterday, but not today, checked all settings 50 mh i 60 as well, and does not work.
      • nibblitz
        • 1300
        That is strange indeed.. Maybe try reflashing the system on it, see if that cures it..
        • skel28
          • Aug 2011
          • 13
          Do you have another HDMI cable and/or another HDMI socket on your TV you can try?
          • jockyboy12
            • Aug 2011
            • 18
            50hz and not rgb output (the other one) try that then reboot and try chang from 1080p to 1080i
            • krus2
              • Sep 2011
              • 4
              Thanks for Your help, but now I think the HDMI port is dead.
              I have also sly hd, and tried with his hdmi cable, but does not work. I changed also settings and nothing. So , my luck .
              Is any hd box similar to sky? with recording series link, and good timer? cheap
              • mitrovskiace
                • Jan 2012
                Openbox HDMI work rarely
                Hello
                I have similar problem with my Openbox s10 HD receiver.
                Before 10 days i put usb to update c lines and after that I lose signal od HDMI output.
                After that I turn of the receiver and next morning when i trun on and next 5-6 days I have picture on HDMI output.
                The past few days I again have not picture on HDMI output until last time (tonight) when turn on receiver and get picture.
                !!! I rarely have picture on HDMI - I think that is the problem with the hardware and it is question to time when HDMI will stop completly bit I don't know.
                Regarding the problem I check all solution - reflash the firmware few times, check on other TV, check with other HDMI cable but nothing.
                Please help how to resolve the problem - as I can read there is a lot of people which have not HDMI output and it is that BUT AS I MENTION I HAVE HDMI PICTURE RARELY - today I have but tomorrow or next few days i have not and after that again i get picture (really strange)
                Thank You in advance.
                • Panther785
                  • Aug 2012
                  • 79
                  try flashing it with a new stable firmware also try it on a different tv also try using one of these cables
                  • slugworth
                    • Nov 2011
                    • 1064
                    the hdmi connector isn't that rugged.
                    It probably popped a few solder connections from too much wear and tear.
                    • mitrovskiace
                      • Jan 2012
                      Regarding the HDMI connector i thing that it is not the problem because when i got picture i move the cable but picutre is still here (if there is some problem with solder connections i should lose signal when move the cable inside the connector).
                      As I mention before i have HDMI picture after few boot up and after that i have not and it repeat continously - I have picture rarely and it is strange.
                      !!! I think that it is problem with hdmi syncronizator-controller with the TV.
                      If somebody have some experience can write and help me
                      thank You
