in us nead firmware to show 110 & 119 in it
  • tab2
    • Aug 2011
    i do not know what to put in the box have one that is from last year but 110 & 119m are missing the outhers i used are for the haf of the world
    nead some help
  • citygent1911
    • Jun 2009
    • 94
    Sorry mate, can you explain in a bit more detail? Are you trying to select which satellites you want available to you?
    • custard
      • 40
      try upgrading the tp list via usb using the file below which has satellites for usa
      • nibblitz
        • 1300
        Its simple enough to add a satellite, in Satellite list from the system menu you can manually enter 110w and 119w into the satellite list, then in Antenna setup make sure Universal LNB is selected, choose your motor setting.. Then you're good to go, just blind scan them..
        • bajadish
          • Dec 2010
          • 12
          Those satellites use a LNB freq of 11250, it's in the list. I agree, its real easy to add a satellite, most of the US TP_PROG's I have seen don't include those two sats, I believe because they are not FTA sats. I had to do exactly as you said to get my box working on those 2 sats.
