Hi all,
Further to my "where is sky news" post, I did some more investigation.
Back ground:
SKY dish pointing at 28.3 (astra) with quad output LNB
SKY HD box in lounge using two of the quad feeds from LNB
Openbox S9 in bedroom using one of the feeds from the quad LNB.
I have no problems with the SKY HD box what so ever. All expected channels received cleanly, no break up.
On the openbox s9, however, I'm having problems receiving vertical polarised channels on the higher frequencies.
By monitoring the signal levels form the 'transponder' menu, I was able to determine that vertically polarised transponders form 10847 Mhz (inclusive) on wards have a very low signal level.
So, because SKY News is on transponder 12207 Mhz V, I'm unable to receive it.
No problems with the horizontal transponders at all.
As an experiment, I disconnected the satellite cables from the SKY box to see if it made any improvements on the the openbox. No improvements were observed.
If the dish was misaligned, surly I would have problems on the SKY receiver too wouldn't I?
Also, I tried connecting the openbox to one of the satellite feeds in the lounge. Known working cable. It made no difference. Still low signal on higher frequency vertical transponders.
Any help would be most appreciated.
Back ground:
