loading files
  • frenchet
    • Sep 2011
    • 16
    loading files
    i have been trying to load clines via usb for ages now with no luck,
    i have done it by remote, but what am i doing wrong?
    is recognises usb stick, says reading cccam.cfg
    then says cant find cccam.cfg
    i have tried changing it to cccam.ebs
    can someone post me an example of the format,
    is it a text file?
  • UyduMan
    • Sep 2011
    • 24
    I'm not sure if the file names are case sensitive. I've seen the same filename as CCcam.cfg. Give that a go.
    • frenchet
      • Sep 2011
      • 16
      i have tried CCcam.cfg, cccam.config,CCCam.cfg
      and combinations of CCcam abs
      do they need to go inside a file ?
      • hooley
        • 470
        It's a notepad file you save it as.
        • ron007
          • Aug 2011
          • 81
          Open up a new text document from right clicking desktop
          copy cline into text doc .then click file(top left corner) save as
          in filename type CCcam.cfg
          Hope this helps not trying to sound to anal just others might read it and help them out as well
          • frenchet
            • Sep 2011
            • 16
            i think the problem was when transfering the file to usb
            it had txt hidden at the end of the name ?
            it has now loaded and appears but doesnt work
            so i must have a line missing or something?
            what is the difference between c: lines & n: lines?
            • lee11168
              • Feb 2011
              • 217
              nlines are more stable plus you can enter your nline with your remote
              • frenchet
                • Sep 2011
                • 16
                i did enter them with remote and they worked ok
                however it locked up every 1 minute regularly for 10 secs or so?
                i presumed it was because you cant add all the details of the other cws lines i have,
                like debug, or keep alive??
                or mabe the software is at fault although it is new(i think) c2hs2 11-07-14:065/cm
                • amarjit_dhillon
                  • 7
                  I had same problem
                  N lines don't work so well in openbox using cccam. I had the same problem. You'll need to convert the n line you have and put it into the newcamd.list file and the box will use mgcamd to connect to your server. you'll be better off. So converting an n line example:
                  N: test.zapto.org 18005 test 123abc 01 02 03 04 05 06 07 08 09 10 11 12 13 14
                  converted is:
                  CWS = test.zapto.org 18005 test 123abc 01 02 03 04 05 06 07 08 09 10 11 12 13 14
                  • frenchet
                    • Sep 2011
                    • 16
                    Amarjit you were correct i converted it to cws and it works. BUT i am back to square one as it still freezes every 1 minute for about 15 secs.
                    i thought it might be the way i entered it (via remote)
                    but obviously not??
                    providing you only need these two lines to make it work
                    i still have a problem!
