OpenBox S10 Dead?
  • scott82
    • 11
    OpenBox S10 Dead?
    Good evening to all.
    I have been using my S10 for a couple of days now with no problems until a few hours ago... I decided to update the channel list with a .DBS file from openboxhdforums via USB. The file transferred OK and I got the " burn to flash" message etc but after the file took and the box restarted I have no image onscreen and no display on the front of the box!
    I know there is power because the led on the front panel lights up but VERY dim, but there is no display.
    Has anybody seen this before?
    The box is original with chip ID# 0d7e
    Any advice would be greatly appreciated.
  • darcu5
    • Jun 2011
    • 944
    Sounds abit odd that m8, looks like it may have to be reflashed using computer and a null modem cable.
    Hope you can sort it out!!!
    • wortho
      • 144
      havnt seen that mate , can you get into the menu ? do a factory reset, and start again, if not maybe the computer link up on here might get you up and running
      • darcu5
        • Jun 2011
        • 944
        you will need this tool on your computer
        • wortho
          • 144
          just a thought could it be a faulty power on /off, might be worth unplugging, and switching rocker switch on and off a few times
          • darcu5
            • Jun 2011
            • 944
            Hi wortho, just so you know your not seeing things, i did put that link on for the ftp tool but wasnt too sure if it would work like that so took it back off
            • scott82
              • 11
              http://www.digital-kaos.co.uk/forums...hd-pvr-205700/
              Unfortunately I can't get anything on the TV at all so no option to try this. All I get is a VERY dim display on the box which looks like the number "8" - knowing my luck the box is probably dead!
              Thanks for all the suggestions guys, just got home from work and will try connecting to the PC in a little while...will report back with findings.
              I have trawled through the forums but can't find anybody else having a similar issue, I just don't understand how uploading a bouquet can cause this...unless the was an underlying issue which kicked in after the reboot.
              Cheers
              • scott82
                • 11
                Update for you all...
                I tried the Erom app listed but had no luck getting it to communicate, instead I tried the "S9-S10 Fix" posted here> http://www.digital-kaos.co.uk/forums...36/index2.html and it worked perfectly. My box is now back to life!
                Panic over...hopefully my experience will help others that come across the same issue as me.
                Thanks to all that have posted with suggestions, I do appreciate the community spirit here.
                Scott
                • darcu5
                  • Jun 2011
                  • 944
                  Nice one, thanks for the update n glad ya got it sorted
