Openbox Clone Safe Firmware
  • nibblitz
    • May 2010
    • 1300
    If you have a Clone Box
    I have it on good authority that the best firmware for your Clone Box is
    March 2011 Firmware: - 25/03/2011
    CONM_CHDS2_CMT_SkyBox.abs
    Audio Sync problems apparently resolved in this release, and rebooting problems not as bad.
    Its totally clone safe, it will not brick your clone, it does not contain clone killer code.
    It will change your boot logo from "Openbox" to a flashier looking "Skybox" logo
    Its ok to use this firmware on either the S9 or the S10
    So if you're frustrated with your clone box running on its factory firmware, give this a go..
    Always system dump your original firmware before upgrading, just in case.
    Then it is also a good idea to factory default your box before flashing the upgrade.
  • sn00pbox
    • Oct 2011
    Openbox S10 Firmware
    Where can I download the latest OpenBox S10 Firmware?
    • mtv1
      The Stig PT
      • 4413
      dumnno m8 here i guess welcome to Digital kaos
      • archers
        • 40
        pmsl snoop hmmm maybe the link above m8
        ok i have loaded the new firmware on my stuck on box after it burn's the box just turns off no life to it. Turn box on and get stuck on agine so no good for me
        • pspmixer
          • Jun 2009
          • 750
          i have serval openbox s9 clone which all run the latest firmware
          in order to update a clone box
          first you have to do a factory reset (this gets rid of everything on your box so save what you want)
          then update you box via usb update (as you would normally)
          then put your details back in e.g sat 28.2, favourite list, tv line etc
          this worked for me all the time i have restarted each box 20 times so i dont brick it (been told after 15 times of restarting each box they will be killec/brick)
          i hvae put the latest firmware in download section at the top
          • joazgroup
            • Aug 2011
            clone box!!
            i got clone box with ori ccid..00D0
            • vun
              • Oct 2011
              • 4
              I WAS INTERTED TO UPGARDE THIS FW BUT AFTER UPGARDE WHY ALL MENUS BECOME GRAY ??(CANNOT SELECTED)
              • estm13
                • Nov 2011
                i'm from malaysia, any safe firmware for clone openbox?
                • slugworth
                  • Nov 2011
                  • 1064
                  always on?
                  Why not just leave the receiver on all the time?
                  As long as it doesn't reboot 10x,you should be fine.
                  I never turn my receiver off,just the tv.
                  • samuidiv
                    • Dec 2011
                    i also just updated with the latest firmware from october 2011. Now it has shown. " You have clone". After that it turned itself off and cannot be turned on again. It just does not react to anything. switched on and off - but same. Any ideas?? Or how I can get back to the old firmware.
                    thank you
                    • slugworth
                      • Nov 2011
                      • 1064
                      rs232 time
                      thank you
                      old style rs232 loader
                      I would have just left the receiver on all the time.
                      • volgren
                        • Dec 2011
                        So does this all mean if I somehow have a clone box which is on factory firmware and has done <10 reboots so far, I can simply do:
                        1) Factory reset
                        2) Dump existing firmware to USB
                        3) Load March 2011 Firmware: - 25/03/2011
                        via USb
                        4) Reboot machine 20 times to make sure it is safe from being bricked?
                        I don't mind staying on a slightly old firmware if this means no more hassle to rescue down the serial port path...
                        • nibblitz
                          • May 2010
                          • 1300
                          Yes, thats correct..
                          • kabiela
                            • Jun 2011
                            • 10
                            This is also a clone version
                            I have also a colleague of mine did his openbox clone S10
                            and it works very well he is satisfied
                            • pizz86
                              • Aug 2011
                              • 23
                              hi i installed the firme wire... but its not allowing me to navigate in the menu. its all highlites in black... any help plsss
