Openbox S9 Remote control OK but not working
  • derpreussen
    • Oct 2011
    • 4
    yes guys, the remote control V3 is OK, I tried with another Openbox S9 and it worked OK, so it is not the RC but the box. Any clue what can be done?
  • derpreussen
    • Oct 2011
    • 4
    is there any electronic drawings of the Openbox S9 to donwload?
    • darcu5
      • Jun 2011
      • 944
      try this on ya remote, may have to try it a few times:
      press menu > infomation >ok , press button "Red, Green, Yellow, Blue, 8"
      Then press the Power button on the remote control
      • derpreussen
        • Oct 2011
        • 4
        thanks Darcus, I will give it a try.
        • smithie46
          • Aug 2009
          • 72
          and if the above dont work the ir senser needs replacing had this problem with a few boxes
          • derpreussen
            • Oct 2011
            • 4
            hi darcus, tried the procedure many times, it diidnt work
            Smitthie, I replaced the box IR but did not help.
            there was a time that suddenly worked for a couple of days then was dead again.
            • smithie46
              • Aug 2009
              • 72
              not sure about s9 but a do no s10 bad caps in power supply cause this problem on clones anyway
              • maguirre
                • Sep 2009
                • 5
                hi
                I have an issue with control remote some keys doesn't work I opened s9 to see if there is any damage condensator but all is ok now after a while all keys are working but then again issue appears
                what can I do?
                thank you
                • limaredfern
                  • Aug 2012
                  • 25
                  Hi guys,
                  I?ve got this same problem with my S10 HD, all of a sudden the remote stopped working, I have tried the sequence above and nothing happened. Remote still don?t working, any ideas? Does it have to do with firmware? Will it work a factory reset?
                  Cheers!
