S11 HD picture quality
  • smallclone
    • Oct 2011
    • 11
    Hi guys,
    Just setting up a Skybox S11 I bought and there is a really bad HD picture, with dots every inch or so. Tried different HDMI cables and inputs. All the HD channels are like that, FTA and scrambled.
    Have updated the firmware, and it is still the same. Any ideas?!
  • tw87
    • Jun 2009
    • 233
    Are you sure you have it set to 1080p mate. If you still have it at 480i it'll look crap.
    IF YOU THINK MY POST HAS BEEN HELPFUL PLEASE HIT
    • smallclone
      • Oct 2011
      • 11
      Yeah, had it at all settings from 480 to 1080 and it's the same.
      • nibblitz
        • 1300
        Is it also the same out the scart socket, or only from HDMI?
        • smallclone
          • Oct 2011
          • 11
          Same via the scart.
          • smallclone
            • Oct 2011
            • 11
            Took a picture. The dots go all across the screen.
            • nibblitz
              • 1300
              That really dont look good does it... I assume your TV is fine with other connected devices? ..
              If you've upgraded firmware and that failed to rectify it then there appears to be some some major defect with your box, can you return it to your seller?
              • smallclone
                • Oct 2011
                • 11
                Yeah, I'm getting a replacement on Tuesday.
                • aftermath
                  • 4345
                  is it not some interference from another device ?
                  • smallclone
                    • Oct 2011
                    • 11
                    Just unplugged everything except the S11, telly and router, which is behind my telly. Same problem.
                    • archers
                      • 40
                      It's the tuner m8
                      • smallclone
                        • Oct 2011
                        • 11
                        Got a replacement box from the seller and it works fine now.
