I'm looking to get an Openbox S10. can i use the current Sky dish i have installed? with the dual coax i have for current HD+ box
complete noob, Sky dish?
Yes you can, it will work fine, but you'll only need one of the cables plugged in. The other cable you could still leave connected to the Sky+ box if you wanted, but the Sky+ recording function wont work with only one lead attached to the Sky+ Box... How many cable connections are on the LNB on the dish? If its just two then you could replace it with a quad lnb (4 outputs) then run another dedicated feed to the openbox, then the Sky+ box would function as it always did with its original 2 feeds... If your dish already has a quad lnb, then simply just run another feed from it..
