New Openbox s10 wont update ??
  • archers
    • 40
    Hello guys just had a new open box from my m8 and im stuck I wont to update software but I keep getting invalid file come up how do I sort this out looked around but cant find any info apart from some one saying to click on misc but that dont work as it dont see the file any help guys thanks
    Softwar on box is CHDS2-11-05-04:0077CMT
    THANKS for any help guys
  • hamguy4
    • Oct 2011
    openbox same problem
    hi archer, my names david from australia this is a little great box but it wont update my aurora on optus c1 at 156east besides that an excellent box .i got mine for $99 us with the us mains plug on it they have a smps in the unit i just cut off the usa and fitted the 3 pin australian plug .,any info on plug ins etc would be greatful ,regards david nsw australia .
    • darcu5
      • Jun 2011
      • 944
      Which software are you trying to put on it, if you start again try downloading a different version of f/w. (Dont forget the clone will bugger up with new f/w so i would check that too) Format your usb, back up your original f/w to usb and save it on computer; incase you ever need it again.. then try to install new f/w
      If it isn't broke, don't try fixin it..!!!
      • archers
        • 40
        Hi m8 i have taken a backup and i have tryed at least 5 set's of F/W and nothing just will not take it
        • nibblitz
          • May 2010
          • 1300
          The firmware you're downloading, is it actually a rar archive that you have yet to extract?
          The firmware when compressed in a rar archive is about 1.5mb, when extracted the actual firmware file will be about 4mb, the 4mb file is what you upload into the box..
          • archers
            • 40
            yea I have unziped it I just dont get it its a little odd to say the least
            • darcu5
              • Jun 2011
              • 944
              make sure it looks like this OPENBOX_S9_110915.abs
              It could be that your usb device isn't compatable with the box. somtimes they do seem picky as to what devices they recognise.. if you can try a different usb dongle
              Failing that, only option maybe hooking up to the computer or lan..
              • archers
                • 40
                This is the thing I have dumped the image from the box to the usb drive no problem and the box can see it no problem. I can load the update no problem but after you hit update and pic file it starts at 0 ends at 100% then comes up with invalid file as you say i can just get it on xp and flash it but dont really wont to do it like that how would i do it with lan ?
                • nibblitz
                  • May 2010
                  • 1300
                  Ok, ermmm, try this, before flashing the firmware upgrade, first restore factory defaults on the box, it will free up memory slots to take & process the upgrade file...
                  • darcu5
                    • Jun 2011
                    • 944
                    edit, does s10 too
                    • wrangles
                      • Oct 2011
                      You could also try an older / other version of the flash file........just a thought as I had similar issues on my S10 a couple of months back
                      • wrangles
                        • Oct 2011
                        If i recall correctly, I had to use a version from May / June in order to get it working correctly - havent had an issue since
                        • jupiterr
                          • Oct 2011
                          • 4
                          Having same issue with S9............
                          Jup
                          • archers
                            • 40
                            its the firmware i put a copy of the dump on my other box and had to fight hard to get a update on it but my othere box still wont tae it so going to null it I think
