image problem
  • pl1976
    • Feb 2010
    • 213
    image problem
    Have 2 openboxs 1 works fine other has gone loopy..put the image 110914 on and was going fine but a tried to upload the new tprog for favourites. Now i have factory reset and put the 110914 back on but cant get the CCcam to go active. Any ideas what i have done ? Its close to going out the window
  • darcu5
    • Jun 2011
    • 944
    did you place a tick to select the line you wanted to use then reeboot, Does it say login or offline?
    • pl1976
      • Feb 2010
      • 213
      It kept changing login then offline. Tried a reboot and tried another file now saying no active and box is ticked. Cline is defo fine
      • pl1976
        • Feb 2010
        • 213
        Just tried the ccam in the working box but still coming up offline/login ? Its from the same server could that be the problem ? Obviously the box is fine though
        • darcu5
          • Jun 2011
          • 944
          most likely problem is ya server, try and get a free 24hr tester from somewhere, at least you will know if your all set up right.
          • pl1976
            • Feb 2010
            • 213
            Yep asked for a tester from another to confirm
            • darcu5
              • Jun 2011
              • 944
              you wont be able to run both boxes with the same c/ you need 2 seperate ones, or they will cut you off..
              • pl1976
                • Feb 2010
                • 213
                Hes supplied me with another line will this not work
                • darcu5
                  • Jun 2011
                  • 944
                  you can try it, but i would of tried elsewhere for a test incase the problem was with him in the 1st place,
