Bricked my s9 help
  • hutchy36
    • Aug 2009
    • 22
    Bricked my s9 help
    Hi guys my S9 is stuck on red light standby tried flashing the box about 30 times but just keeps either not doing anything syncronizing stb or gives a stb memory error any ideas please
  • nibblitz
    • 1300
    what makes you think you "bricked" it ? did you do something that rendered it inoperable? Or could it be a component (psu) failure that has it remaining in standby..? Did it just stop working?
    • hutchy36
      • Aug 2009
      • 22
      Thanks Nibblitz need help to work out what went wrong please. I switched my s9 off and disconnected it to try my friends box out for him, when I connected my own box back up it would not come off of standby, I managed to re flash the box and get it going again but when I disconnected the power to relocate it it was dead again, got the same problem if you have to reboot to upgrade it just goes back to standby mode. Anybody any ideas/support please, can you buy a new psu if thats what is needed
      thanks to all
      • hutchy36
        • Aug 2009
        • 22
        Update on my openbox problem. Managed to flash the firmware and get the box up and running again only problem is that you cannot switch it onto standby or off ,if you dare it will maybe not start/boot again (a hit or a miss box) and your then back to a dead box , anyone any ideas what could be wrong with the box, all functions working as they should once running and very stable..
        Thanks guys
        • jester1965
          • Nov 2010
          • 38
          helo
          just a thought but it may be a loose power cable on the inside of the box, when you move the box you may dislodge it but when you put the box back down it makes a connection?
          Thanks guys
          • hutchy36
            • Aug 2009
            • 22
            Thanks Jester already opened it up and tried all the connections didn't make a difference working fine but I can't turn it off just in case, thanks again
