Yes I did set the dish up correctly, I had it working before but I started experimenting with go to x function and I messed it up and I cannot get the USALS function to work. I replaced the motor several times but it is not the motor. I did a factory reset, reloaded previous Dump versions and still the same.
Yes The coordinate are correct I had everything working before but after I played wit the Go to X function and did recalculate, I could no longer make the USALS function to work correctly.
I have tried several new motors the result is the same. I think the openbox must have a constant. when I go to limit setup and specify go to to refernce it goes to zero on the motor but when I specify in the satellite table say 5 west it goes to 30 east on the motor instead of 5 west.
i did a factory reset after i everything is fine now so i stand by that saying if it aint broke dont try fixin it ,,,,,,,,i cannot get my test cline to work does it connect automaticly when i hook up my internet or do i have to change any settings on my openbox
