OPENBOX RED LIGHT PERM ON
  • scottj130208
    • Apr 2011
    • 323
    i have an openbox s10 seems to be an origininal box
    the box will not come out of standyby also will not sync i have tried over 10 different f/w and several loaders but still wont flash im using an rs232 direct serial connection no usb connection involved but this just wont flash erom brings up many error stb memory error also set upgrade mode error tried different loaders new and old
    is it fair to say this box is bricked or is there any way of fixing this
  • Manic01
    • 5117
    A how to guide on how to fix a corrupt firmware image in the OpenBox S9 Linux based satellite receiver. Even if it seems bricked. Box does not respond or displays On? If your box does not respond, or just displays ?On?, there is a good chance the current firmware on the box is somehow corrupt. This could be from a number of things. To solve it, you will need to flash it with the firmware again, but as you can not access it, you may think the box is stuck. You will need to use this tool, connect a serial lead to the box and follow the instructions. Hopefully it will bring your box back to life. please use this tool to upgrade your Openbox S9 HD if the box appears to be dead
    • scottj130208
      • Apr 2011
      • 323
      hi thanks but the box will still not flash will not connect says set upgrade error any ideas or is this fit for the bin
      • slugworth
        • Nov 2011
        • 1064
        branded
        if the box was flashed with an oddball flash that has a different bootloader section,you may have to replace the flash chip.
        I would check to see if the rs232 port is actually working by using a terminal program and see what the screen says when you power up.If the rs232 is working the pc screen should show app init ok.
        • scottj130208
          • Apr 2011
          • 323
          hi yes the rs232 port is working but still wont flash any ideas what i could do now
          • slugworth
            • Nov 2011
            • 1064
            screen shot
            take a screenshot of the error message(shift print screen keys on pc)then paste into paint and save as a jpeg.
            You start the loader then when it says sync you turn the receiver on in the back.
            • scottj130208
              • Apr 2011
              • 323
              have many errors coming up on erom read raw error stb error
              it will not go through to next stage to flash
              • scottj130208
                • Apr 2011
                • 323
                here is a pic
                • Dub12Dave
                  • Feb 2011
                  • 142
                  Are you trying to flash using a serial to usb jobby or are you using and old desktop with port? When you click for the flash to begin is the box powered off and then switched on as quickly as possible using the rocker switch at the back as sometimes it is just a matter of timing.
                  • scottj130208
                    • Apr 2011
                    • 323
                    yes using dedicated serial com1 port no usb and clicking next when powered off tried various combinations of times but still no luck funny thing is i had it working once before last week switched it on in the morning then it was dead again dont know whether to give up as spent hours on it now still no luck with it
                    • Dub12Dave
                      • Feb 2011
                      • 142
                      If you haven't already have a read here http://www.digital-kaos.co.uk/forums...-cable-233298/ from my own personal experience with this the only software that would work for me was the March firmware think it was the 15th or something, keep at the timing thing also.
                      • scottj130208
                        • Apr 2011
                        • 323
                        tried this already but will try again i just dont want to throw it away if it could still be fixed will try the timing again and thanks for your help
                        • scottj130208
                          • Apr 2011
                          • 323
                          erom says set upgrade mode error any ideas
                          • slugworth
                            • Nov 2011
                            • 1064
                            loaders
                            I would try different loaders.There were some that had no ini files or eromclient.abs, everything was in the .exe loader.
                            Some loaders let you select the individual files to load.Or maybe even try to do a flash dump to see what the receiver is loaded with.(dump data mode instead of upgrade mode in loader)
                            • scottj130208
                              • Apr 2011
                              • 323
                              hi wont dump either erom says set upgrade mode error
