Along with the reboot loop which seems o have settled down now, I have been having a problem getting channels, Sly Sports 1 HD, supplier told me it was the LNB, so changed the octo lnb on minidish to Zinwell, I should also point out that I tried the Openbox hooked to my main dish and secondary dish Invacom 0.3 and Invacom c120, no signal on those as well.
Same issue with new Zinwell, so whilst investigating thought I would check Antenna setup specifically the LNB frequency that was on set to default 9750 -10600, low and behold if I changed it to 9750 SS1HD signal banging in 87 & 72% however lose lots of other channels like Sly1 so tired one of the other universal settings, 9750-10550 seems the ticket both ss1hd and sly1 in transponers list signal as above, however here is the bizarre thing, the channels now remain scrambled where they were clearing before?
I rescanned the 2 frequencies with the universal set to the 9750-10550 both lock and then clear?
Why would changing the higher end of the LNB frequency stop the sigal from being cleared, as when setting the 2 channels to 9750 and 10550 to get the signal the picture clears, I know I can do a rescan and then will have to reorder all the channels
but seems truly bizarre that a frequency change on the LNB menu is affecting clearing?
