hi all, bro brought s10 box today, got it flashed with firmware and imported latest channel list, problem we have is the channel list we have on the box is pretty mixed up, how do we edit the channel list manually and import channels from main sat list to the favourites, hope someone can help, regards tool
editing channel lists manually
I hope it will help youAttached FilesComment
select menu - program - favorite.. here you can rename favorites to whatever you like
then scroll up to the tv channel list, on the top it should say all sat, then press fav and select a channel, your favs list will come up and you can select to drop it in any of them...
Once you have all the channels you like (which will be after a good hour or 3
) you can then; in the channel list again. scroll across to says fav 1 and select move, this will then allow you to select a channel and move it up and down the list..
Good luckIf it isn't broke, don't try fixin it..!!!
