S10 recording
  • yabs
    • Nov 2011
    • 8
    S10 recording
    How much high definition recording time will I get with 400gb hard drive?
    Thanks in advance
  • nibblitz
    • 1300
    It all depends on what bitrate the HD is being broadcast out at.. But roughly estimating, if you allow for 10gb hard disk space per hour recorded then I think you'll see you can still record quite a lot..
    • slugworth
      • Nov 2011
      • 1064
      burn
      if the hd recording is worth saving,you could burn it to dvd and clear up some space on the hardrive.
      I've had some hd recordings that were 1gig per 5minutes.
      • yabs
        • Nov 2011
        • 8
        Thanks guys, i guess it's a try and see?? so long as the 400gb allows me to do a couple of movies i can then rip them to my Mac and "badoooosh" were done.
        again guys thanks.
        • slugworth
          • Nov 2011
          • 1064
          mpeg_streamclip
          I use osx86 for internet so I did a search for a .ts player.
          Mpeg_streamclip 1.9.3b7 will play the .ts files from hardrive and gives you the option to convert to mpeg or whatever.
          You need quicktime installed with the quicktime mpeg2 plugin installed.I found that on rapidshare.I use quicktime 7.6 and the streamclip program ran fine.
