can i transfer firmware from 1 s11 to another? inc channel list help plz
  • total newby
    • Feb 2011
    • 183
    hi is it possible to transfer a updated image from one openbox s11 to another and keep the channel list also , reson asking iv got a s11 all set up lovely with latest firmware and my channels took me 3 hrs to set up and i want to transfer the whole lot onto my bros box from mine thanks p.s both boxes are the same
  • mast
    • Nov 2010
    • 1027
    Hi
    Yeh you can, dump the image selecting the first 2 options onto a usb stick then on the 2nd box choose upgrade by usb and all should be fine. Are they both originals just make sure if dump is an original and 2nd box is a clone then would be problems.
    Regards
    • mast
      • Nov 2010
      • 1027
      Hi
      Forgot to mention I would make a dump of the channel list too for future use.
      Regards
      • total newby
        • Feb 2011
        • 183
        Originally posted by mast
        Hi
        Regards
        so is it the HDS2_DUMP
        and the TP_PROG.dbs
        files i copy to my usb stick, cheers
        • mast
          • Nov 2010
          • 1027
          Hi
          Thats right, when you are dumping the image select the first 2 options HD2S_ Dump.abs and system setting, and in the channel dump its just the TP_PROG.dbs
          Regards
