how to rename the TP_PROG.dbs extension to TP_PROG.abs??
  • pizz86
    • Aug 2011
    • 23
    dose anybody knows how to rename the TP_PROG.dbs extension to TP_PROG.abs pls? thanks
  • vorlon2257
    • Sep 2011
    • 356
    Right click on the TP_PROG.dbs and change the d to a and save.
    Do the same when changing back from a to d
    Simples
    • mast
      • Nov 2010
      • 1027
      Hi
      Simply right click it and rename it. I would actually make a copy of original and then rename it.
      Regards
      Edit: vorlon beat me to it and spot on.
      • Manic01
        • 5117
        To change the extension of a file, make sure you have view file extensions enabled, by simply doing the following:
        1 .. Open a folder [any folder will do]
        2 .. Click the Organize tab button.
        3 .. Click the Folder & Search Options.
        4 .. Click the View tab button.
        5 .. Now make sure the [Hide Extensions for known file types] box is blank, ie, no tick displayed.
        6 .. Click apply and then close the folder.
        7 .. That's it, you should now be able to change a files extension by right clicking on the file and selecting the Rename option.
        • Manic01
          • 5117
          Also if still having issues
          1. Open a folder or open explorer
          2. Click the Layout button (to the left of the Views button
          3. Click Folder Options
          4. Click the View tab
          5. Uncheck Hide extensions for known file types
          6. Click OK
          After this, the file extensions should be visible and no longer hidden.
          • slugworth
            • Nov 2011
            • 1064
            no need
            there should be no need to rename.
            • darcu5
              • Jun 2011
              • 944
              On xp i use to change it whilst it was still in the wiinrar folder then drag it to desktop, open it an change whateva with pvr800 drag it back to winrar, rename it back to dbs then drag it back out .
              • joveljic
                • Jun 2014
                • 8
                This method doesn't appear to be working on my Amiko box. I renamed the file successfully but the channel list update failed. Does something need to be tweaked within the file to make it compatible with non-openbox/skybox boxes?
