hi ,does the 2 pin plug version have a fuse as my box has has just went off and seems totaly dead\?
openbox s11 2 pin fuse??
Tags: None
I am having the same too, the box worked for about a month then just dead I have completely replaced the power cable with a standard uk one and still no luck, replaced the on/off switch and still no good. I now have two openbozes which seem to have the same fault the s11 which will not show any sign of life when switching on and a s9 which all i get on that one is the standby LED and nothing else. seems to me like its the same fault on both.
Looked everywhere and cant seem to find anything on how to fix this but i have ordered a null modem cable and usb converter off fleabay to give re-flashing the bootloader a try. im convinced this should fix it http://www.digital-kaos.co.uk/forums...ed-s10-248792/
PS no fuse in a 2pin plug but there does appear to be a small internal fuse in the s11 on the power board, if you want to open the box and take a look. Mine looks fine tho :/ also even tried the power cable/Switch and power board from the S9 in the S11 but still no go.Last edited by ru5; 16 January, 2012, 21:04. -
this not do the trick EURO 2 PIN PLUG TO UK MAINS POWER 3 PIN FUSED PLUG ADAPTOR / CONVERTER, 3A WHITE | eBayComment
ethernet effect
On a brain dead s10 I noticed that the pc detected the network device in the s10 when I turned the receiver on in the back.(taskbar network icon)There were no lites on the receiver lan connector,but the pc still detected it as a connection.This MAY be a quicky test for a power supply working,at least the +5v part.
