motorized dish diseqc 1.2 problems
  • alansugar141
    • Apr 2011
    • 10
    I was just wondering has any one got s11 box and had problems with motorized dish?
    every time i go to change postion the box reboots.
  • dekd1
    • Dec 2010
    • 40
    Yes ! Doing my head in too... I can add a little to the mix though - Motor is TM2300. Unit will drive the other setup with alsat motor. Motor will move just fine and will not reboot with lnb cable disco'd. Tried a spare S9, borrowed S10..... Reboot on all. Little success with keeping channels on H polarisation. Can move without rebboting, also when plonking in a Vision Line Amp, partly working. Something to do with my LNB/Motor combination, but I'm a little stuck for further fault finding. I'll keep you posted. LNB is Triax single....
    • alansugar141
      • Apr 2011
      • 10
      openbox s11 1.2 motorised dish problems
      seen seen am not the one only with this headache the seems a quite a bit of people experiencing same issues my mate he should be here in an hour if he cant find fault i know for sure he wont rest till he figures it out i let you later what happens.
      • dekd1
        • Dec 2010
        • 40
        Problem solved ! Openbox S11, S10, S9 for me will not work woth TM2300 motor. Swapped motor for friends fortec and all good. Not coincdedence with cables/connectors. Went through fualt finding, new lnb, temp fly lead etc. Openboc powers alsat dark, fortec star, but not TM2300. I was lucky a pal let me trade units. It was a quick test, motor connected by receiver with short lead and also LNB connected as my moved withiout lnb hooked up. Stepped E/W fine with new motor. Good luck !
        • alansugar141
          • Apr 2011
          • 10
          yh your right mate had to get my motor changed aswell from stab 120 hh motor to alsat dark motor metel gear stright swap including fitting 3 days waiting to weather got better ovrall pleased.
