v format openbox s10 hd pvr..
  • isaax
    • Jan 2012
    haii
    i have ready openbox s10 hd pvr.i try to setup.when i open the monitor show press v format to switch..in decoder show no channel.how i can do????please help master......
  • Manic01
    • 5117
    Load a channel list.
    • isaax
      • Jan 2012
      how to load channel list?i try to press button menu still show no osd and press v format to switch..i try reboot still same..any idea???
      • darcu5
        • Jun 2011
        • 944
        do you use hd lead or the yellow white red lead?
        If it isn't broke, don't try fixin it..!!!
        • darcu5
          • Jun 2011
          • 944
          Press the v-format button once, wait 15 - 20 seconds then press again, there are about 7 different settings to change so be patient and remember to wait before pressing v format again..
          • slugworth
            • Nov 2011
            • 1064
            finger
            or finger the remote blindly
            menu
            right 2x
            ok
            1x down
            ok
            right until you get a picture on tv screen
            • isaax
              • Jan 2012
              haii i from malaysia.my satelite is measat.how to setup it??
              • darcu5
                • Jun 2011
                • 944
                http://www.lyngsat.com/mea3.html If this is it then you will have to go into satellites and select 91.5, then do a single scan on it, if it's not on your list of satellites then you can add it manually, then add all the transponders manually,
                • slugworth
                  • Nov 2011
                  • 1064
                  add it manually,then do a blindscan.
                  • wahlaueh
                    • May 2012
                    Hai, I m also from Malaysia, would appreciate if you can provide steps or procedure to set up opening s 10 . Tq many times over. My email [email protected]
