I take it you are now running with component out to watch programmes on Openbox?
I have seen a few tuners which had faulty HDMI ports, do you have kids at home as there is a few settings within Menu that can knock HDMI out depending on TV.
Go to Menu select -> System Setup -> TV System -> Video Out, within this there are two options RGB & YUV, if you select RGB then you have only two resolution options 480i & 576i, (some tV's will only support this )there is also an Auto option, if you wish to access the full resolution options you must select YUV then you should have access to full resolution options currently available [480i - 480p - 576i - 576p - 720p 50 - 720p 60 - 1080i 50 and finally 1080i 60.
