I got some problem with my cccam connection. It can work for several hour and then it got offline.
cccam offline
Mine use to work fine without it on too, but decided to set it to on all the same, but the other day i'd beed messing about sending stuff from lappy to box over the lan connection and had to turn dhcp off to connect, i forgot to switch it back on and the box ran ok for rest of day/night.. the following day tho my line would work for anything between 5 - 20mins then suddenly drop.. other openbox work fine, so thought i was kicking kids out there bedroom for footy
. .then checking the box over i realised i'd left dhcp off; switched it back on and it has worked fine since..
We do have 2 ps3's 2 comps and 3 lappys, blackberrry's ipod and tablet connecting up all time tho, so i think there was a conflict
thats a strange one mate, and it works fine in other box, no dropping off?? Most likely a sever problem as rigsby71 suggest.. i would reccomend trying a test, just to see how that goes.. if that stays alive without fault then you know its deffo your serverIf it isn't broke, don't try fixin it..!!!
what f/w does it have on it? the new january clone safe f/w which shady put on is suppose to be stable, had some sort of fix for cam freezing and lag http://www.digital-kaos.co.uk/forums...rmware-248475/If it isn't broke, don't try fixin it..!!!
