1 box was took apart and when checked no resister had blown put it back together and it worked fine - 2nd box resister had blown still to try 3rd box
Do you mean capacitors, rather than resistors?
As posted by johnboy97, I have also come across boxes with extremely loose spade connectors on the mains switch. It's worth giving them a slight tug to make sure they are a tight fit whenever you need to take the lid off.
