does anyone else have a bad problem with lipsync of the s11 hd? mine is nearly a good second out
openbox s11 hd bad lipsync
Just got the S10 today, well gutted as the lip sync is out on mine aswell, I know this will drive me crazy so unless there is a fix it's just a door stop ...
Can anyone help ?? -
version is C2HS2-11-12-13:0481CMT
is there another which will solve me lip sync issues ??
Again, a big thanks for any replysComment
I thought you may of had an older version on as they use to have problems with the lipsync earlier in 2011 - 2010 i can only vouch for the firmware i use which doesn't have any issues on my s9 an s10 and that is 14/09/11.
Here's a link to the f/w on my s9 and s10 post number 18
Last edited by darcu5; 4 February, 2012, 13:28.If it isn't broke, don't try fixin it..!!!
Sorted out the lip sync on my S10, got a test line and I'm getting glitching in the picture, I've tried this on 3 different firmwares with the same result, it's not all the time but enough to be annoying, some are worse than others...
I've rebooted the router, nothing else connected to draw bandwith but still glitching/freezing but the lip sync is now spot on...
So got another test from another provider and still the same glitching/freezing, the same as the first test line from another provider...
Is this to be expected on all boxes ? OR am I just doing something wrong ? I have a 10mb connection which constantly gives around 7mb test download speed, is this fast enough ?? OR mabey could it be that both test lines are pants ??
Appreciate any help/advice....Comment
Can anyone PM me and recommend any good test lines so I can see if there is a problem with my box/setup, i've emailed the test line and they said to open ports/ contact my isp to open ports, i've opened the ports on my router but still intermittent glitches/freezing.... driving me nuts...Comment
Info
Hi,
I am using F/W 2011-12-13 from Download / Software / Openbox S9/S10/S11/S12_Shenzhen Yojia Technology Co., Ltd.
I would try that firmware(if you have not already).
Good luck
Thanks both, connected with a lan direct to router, as I've said i've forwared ports but still glitches/freezing...Comment
