S9 and dual line from LNB
  • slideaway
    • Jun 2009
    • 15
    Hi All
    I have a $LY dish with dual coax running from it, presume for $LY HD plus.
    My S9 scans for all channels on Astra satellites and picks them all up but shows no signal on most music and a few entertainment.
    Do I need an in-line signal amp for this type of setup and just use on one of the coax inputs?
    Tried S9 on a single LNB setup and it works fine
  • darcu5
    • Jun 2011
    • 944
    i'd check the tp's are in there 1st mate, go to kingofsat.net find the transponders for those that are missing and check them in your s9, if they aren't there you can add them, if they are then scan just the one tp and see if it finds the missing channel
    • slideaway
      • Jun 2009
      • 15
      Is it worth trying a signal amp?
      • darcu5
        • Jun 2011
        • 944
        Yeh mate,, but i would also check the tp's are there 1st.
        • slugworth
          • Nov 2011
          • 1064
          why would you need a signal amp?
          If the signal is low,something is radically wrong with the setup.
          • darcu5
            • Jun 2011
            • 944
            it worked on other dish.. it's either transponders aint there, signal crap so will need an amp, failing that a lnb.
            Start fault finding at the cheap end 1st
            • slugworth
              • Nov 2011
              • 1064
              work with what you got.
              make sure the dish is aimed properly and you only have 1 receiver connected.
              • darcu5
                • Jun 2011
                • 944
                yep; anyway, moving along now, like i was saying from the start...... Check the transponders on kingofsat.net for the channels that do not work, if the transponders are not on your box then manually add them in the menu - installation - transponder list, and scan them.. also check the lnb freq. menu - installation - antenna setup, try setting this to universal (9750 - 10600)
                • slideaway
                  • Jun 2009
                  • 15
                  Played around with TP's today and it appears that all A$?ra 2A South has a signal strength of 10% where as all other Sat's are over 70%
                  Is this likley to be miss-allignment?
                  • darcu5
                    • Jun 2011
                    • 944
                    Yeh you could try moving the dish it may be a budgies dick out, if you get no joy then it's looking like lnb is causing the problem and will need replacing. I've seen quite a few with the same problem. Can pick them up for around 6 - 10 pound on ebay
                    • slideaway
                      • Jun 2009
                      • 15
                      Perfect - In line amp sorted it straight away - All channels now viewable
                      • darcu5
                        • Jun 2011
                        • 944
                        nice one, glad you sorted it it mate, thanks for letting us know
