openbox s9 problems
  • pspmixer
    • Jun 2009
    • 750
    openbox s9 problems
    my openbox s9 last night decided it didnt want to work with any hd or sd movies channels
    i tryed different channel lists, different firmware, rescanning (blind scan) and swapping channels via find on remote but they still didnt work
    how can i sort this
    thanks in advance
  • DW190
    how can i sort this
    thanks in advance
    If it was just movie channels it could have been your server.
    • pspmixer
      • Jun 2009
      • 750
      i use the same server on my vu+ box and its fine on all channels
      • darcu5
        • Jun 2011
        • 944
        check tp's are there and the signal strength on those tp's, check lnb freq set to universal 9750 -1600.. if still no joy lnb may be jiggered or on its way out
        • pspmixer
          • Jun 2009
          • 750
          Signal on tp is 42% intensity 10% quality
          How do I save it another one
          My lnb freq universal is set to 9750-10600
          My dish works fine on my Vu+ duo downstairs
          • Manic01
            • 5117
            Are you using a quad lnb on sky dish?
            • darcu5
              • Jun 2011
              • 944
              It could be that your using another box on the same dish, the openbox sometimes drops its signal if both boxes are on at the same time, try upplugging your other box and see if the signal comes up on those tp's
              • pspmixer
                • Jun 2009
                • 750
                Yes
                Signal didn't change wont vu box was turned off and unplugged from dish
                • pspmixer
                  • Jun 2009
                  • 750
                  attached picture of details
                  • darcu5
                    • Jun 2011
                    • 944
                    you could try one of the sloping inline amp things on ebay, it suppose to be a fix for missing channels. for 4 quid it's worth a try just make sure its a sloping 13 - 18 and not the 20 or that could crash signal altogether
                    this is what you want http://www.ebay.co.uk/itm/In-Line-Si...#ht_2478wt_982
                    which is pretty much same as what this bloke sellin for nearly double that price http://www.ebay.co.uk/itm/No-Signal-...#ht_2197wt_932
                    • pspmixer
                      • Jun 2009
                      • 750
                      ive just bought two of them
                      • darcu5
                        • Jun 2011
                        • 944
                        hope that solves your problem mate, let us know how it goes
                        • pspmixer
                          • Jun 2009
                          • 750
                          signal is now at 91% but will see how it goes
                          • pspmixer
                            • Jun 2009
                            • 750
                            got a new problem now
                            now of my channels work but i have 82% signal
                            my line says its online plus dhcp settings is turned on as when i turn it off i know doesnt work
                            tryed a blind scan and new channel list but still no channels work
                            • Shady
                              Shite Link King
                              • Dec 2010
                              • 6404
                              DHCP needs to be off on my box.. try it
