not seen any around since last may so they probs out dated now, i found the easiest way for multisat was to put a decent 28.2 channel list on, then scan 19.2, 13, 16, and a few others and just stick them in alphabetical order so the channels are easier to find. Deleting a few crappy channels along the way, as the box only holds 5000 channels
You can sort them via the setup menu under Channel lists but you have to do all Satellites individually or at least I did.
As for 19East etc.
I ended up giving up searching and just scanned all the sat's I was interested in. Then deleted all the crap channels before sorting stuff into relevant favorites folders. I used the channel editor on my PC and it took an afternoon because I also renamed channels so that I could actully tell them apart.
Channel name and editing really lets this box down badly.
I'd be happy to post my listing when I'm happy with it but want to see if I can get some of the low signal issues I'm having sorted first once my new LNB gets here.
I will post it up here for all once done. __________________________________________________ ______ SKY TV Never before in history has so much been paid by so many for so little.
